ЭБУ двигателя Н3 Турбо 4G63S4Т 2.0
Сообщений в теме: 4
  DIMA66 727 сообщений
Отправлено 05 июня 2015 - 05:21
DIMA66
  • 727 сообщений
Распиновка ЭБУ Delphi MT80
K20 Engine Control Module X1 (LXT)
1 Ignition Control Timing Control (2)
2 Heated Oxygen Sensor Low Signal Bank 1 Sensor (1)
3 Throttle Position Sensor Low Reference
4 Throttle Position Sensor 5 Volt Reference
5 Clutch Apply Sensor Voltage Reference
6 Manifold Absolute Pressure Sensor 5 Volt Reference
7 Not Used
8 Not Used
9 Intake Air Temperature Sensor Signal
10 Heated Oxygen Sensor High Signal Bank 1 Sensor (1)
11 Not Used
12 Knock Sensor Signal (1)
13 Generator Field Duty Cycle Signal
14 Heated Oxygen Sensor Heater Low Control Bank 1 Sensor (1)
15 Exhaust Gas Recirculation Valve Position Signal
16 Not Used
17 Ignition Control Timing Control (1)
18 Exhaust Gas Recirculation 5 Volt Reference (2)
19 Intake Air Temperature Sensor Low Reference
20 Crankshaft Sensor Signal (1)
21 Crankshaft Position Sensor High Resolution Signal
22 Exhaust Gas Recirculation Position Sensor Signal
23 Not Used
24 Coolant Temperature Sensor Low Reference
25 Not Used
26 Throttle Position Sensor Signal (1)
27 Manifold Absolute Pressure Sensor Signal
28 Knock Sensor Signal (2)
29 Engine Coolant Temperature Sensor Signal
30 Charge Indicator Control
31 Not Used
32 Not Used
33 Not Used
34 Manifold Absolute Pressure Sensor Low Reference
35 Clutch Apply Sensor Low Reference (LDE/LXV/2H0)
Clutch Apply Sensor Low Reference (LXT/LLW)
36 Not Used
37 Exhaust Gas Recirculation Valve Motor Low Signal
38 Clutch Apply Sensor Signal
39 Throttle Position Sensor Signal (2)
40 Oil Pressure Gauge Signal
41 Not Used
42 Not Used
43 Not Used
44 Not Used
45 Fuel Injector ECM/PCM/VCM Control (−SAE)
46 Fuel Injector ECM/PCM/VCM Control
47 Not Used
48 Not Used
49 Not Used
50 Not Used
51 Not Used
52 Not Used
53 Not Used
54 Not Used
55 Not Used
56 Camshaft Position Sensor Signal
57 EVAP Canister Purge Solenoid Control
58 Cruise/ETC/TCC Brake Signal
59 Exhaust Gas Recirculation Valve Sensor Signal
60 Not Used
61 Throttle Relaxer Motor Control
62 Not Used
63 Fuel Injector Control (2) (−SAE)
64 Fuel Injector Control (3) (−SAE)
65 Fuel Injector Control (1) (−SAE)
66 Fuel Injector Control (4) (−SAE)
67 Throttle Relaxer Motor Low Reference
68 Not Used
69 Not Used
70 Not Used
71 Not Used
72 Not Used
73 Not Used
K20 Engine Control Module X2 (LXT)
1 Run/Crank Ignition 1 Voltage
2 Accessory Wakeup Serial Data
3 Run/Crank Ignition 1 Voltage
4 Not Used
5 Not Used
6 Not Used
7 Fuel Level Sensor Low Reference
8 Not Used
9 Not Used
10 Not Used
11 Not Used
12 Accelerator Pedal Position Signal (1)
13 Not Used
14 Fuel Level Sensor Low Reference
15 Not Used
16 High Speed GMLAN Serial Data (−) (1)
17 Cruise/ETC/TCC Brake Signal
18 Cruise/ETC/TCC Brake Signal
19 Not Used
20 Not Used
21 Not Used
22 Powertrain Main Relay Fused Supply (1)
23 Clutch Apply Sensor Voltage Reference
24 Not Used
25 A/C Refrigerant Pressure Sensor Signal
26 Not Used
27 Accelerator Pedal Position Signal (2)
28 Not Used
29 Not Used
30 Heated Oxygen Sensor High Signal Bank 1 Sensor (2)
31 Not Used
32 High Speed GMLAN Serial Data (+) (1)
33 Not Used
34 Not Used
35 Accelerator Pedal Position 5V Reference (2)
36 Accelerator Pedal Position 5V Reference (1)
37 Clutch Apply Sensor Signal
38 A/C Pressure Sensor 5V Reference
39 Accelerator Pedal Position Low Reference (1)
40 Not Used
41 Vehicle Speed Signal
42 Not Used
43 Ground
44 Ground
45 Not Used
46 Heated Oxygen Sensor Heater Low Control Bank 1 Sensor (2)
47 Not Used
48 Check Engine Indicator Control
49 Primary Fuel Level Sensor Signal
50 Not Used
51 A/C Compressor Clutch Relay Control
52 Clutch Apply Sensor Voltage Reference
53 Not Used
54 Accelerator Pedal Position Low Reference (2)
55 Heated Oxygen Sensor Low Signal Bank 1 Sensor (2)
56 Not Used
57 A/C Refrigerant Pressure Sensor Low Reference
58 Not Used
59 Not Used
60 Not Used
61 Not Used
62 Engine Main Relay Coil Control
63 Not Used
64 Engine Reverse Gear Switch Signal
Transmission Park/Neutral Signal (1)
65 Not Used
66 Low Speed Cooling Fan Relay Control
67 Low Speed Cooling Fan Relay Control
68 Not Used
69 Not Used
70 Starter Relay Coil Control
71 Fuel Pump Primary Relay Control (−SAE)
72 Not Used
73 Ground
  Labirint 962 сообщений
Отправлено 05 июня 2015 - 08:10
Labirint
  • 962 сообщений
  • Hover 2,4 Январь 5.1
Сам прозвонил или есть источник откуда взял распиновку?
  ConstZ 1 673 сообщений
Отправлено 05 июня 2015 - 08:32
  • 1 673 сообщений
Похоже, "копипаста" от Chevrolet Cruze.
  asis 1 808 сообщений
Отправлено 06 июля 2015 - 09:09
asis
  • 1 808 сообщений
  • New turbo МКПП
Распиновка блока на турбо ховере другая с указанной не совпадает. Проверяли с грамотным диагностом.
Отправлено 26 декабря 2016 - 21:48
serand
Так ни кто и не нашел распиновку блока управления МТ 80?
